What's the most boost pressure you can run on a ph2 pump before it can no longer cope?
same for the ph1 aswell please.
i used to know what it was but have forgot :(
obviously sligtly diff due to the efi setup but the standard ph1 pump i was using worked ok upto 20 psi ,im sure i ran 25psi with the carb in situ with no probs :)
i was told in the past that instead of searching solely for a ph1 pump you can infact use other fuel pumps from fuel injected cars providing there external pumps.
think rs turbo/xr3i etc
To be fair a pump of any modern petrol turbo car would more than be upto the job.
all rs turbo, xr3i fuel pumps are mounted externally, unless its the 90 spec with the EFI engine, its located inside the tank. if you use one of these pumps, the escort has to be pre 90`s:agree:
anyone remember what the limits of the std phase 2 pump is?
