volvo b18ft conversion help!?? for those who've done one!!
i'm in the middle of doing the volvo conversion.. can anyone help with a couple of plugs and wires .. i simply cant remember where they were unplugged from!! for some reason i didnt label them as i did all the others!
this multiplug near alternator
http://i94.photobucket.com/albums/l1...ber2009009.jpg
and one the same near inlet
http://i94.photobucket.com/albums/l1...ber2009008.jpg
and one eyelet in the middle... does this go to live or earth!?
http://i94.photobucket.com/albums/l1...ber2009011.jpg
Re: volvo b18ft conversion help!?? for those who've done one!!
i've figured out where all these wires go... one is for reverse switch the other is a live for fuel pump relays. the one near alternator seems to serve no purpose..
however i still cant get it to run.. i've connected thick grey wire to live. red/grey to fuel pump etc.
if i put a little petrol in the inlet it fires right up..
is there anyway of testing the injectors? also the fuel pump wont come on unless i put an earth on the bottom of one of the relays...
anyone ?? i'm going out of my mind here!!
check yr tdc lead, the fuell pump wont fire untill it see's a signal
also check your engine earths
if no luck i have a loom or sale;)
the bloody thing started first time this morning!! ran it for a while ... fine... went back to it half an hour later and it wouldnt go again.. so i'm thinking earth's or earth problem now.. which is the tdc lead? do you mean crank sensor?
yeah crank sencor
disconect the ecus for a an hour then try
coil paks are crap
have u checked for water in the bores
shody conection in wireing
i've ordered a crank sensor and cleaned all the earths up.. it started today. got it warm.. all seemed fine.. started it a few times... no problem... left it for an hour or so.. nothing... the petrol i used in my makeshift fuel tank is rather old... so that may not help... i've not checked for water but it doesnt steam when running... once i've got the fuel pump plumbed in properly and a new fuel filter i think it'll be ok...
