Hi can ne one help I'm wanting to move the header tank to the other side can ne one help tell me how ? Thanks Steve
I moved mine over to let the air filter come away from the turbo.
I would however recommend that you relocate the header tank to the scuttle. Its away from the hot stuff , and higher than everything so will help to self bleed.
Can not put in there got my charge cooler tank in there with the battery
I'm just about to do this to mine and I'll be putting mine between the drivers headlight and the brake fluid reservoir.
Loads of threads and pics on this subject. Do a search.
