WANT TO SHIFT THIS BY NEXT WEEK
Not looking for much.. need it shifting for space
I will price items individually upon request but will more than likely let most bits go together etc for the same price to get it gone
OE GTT Hoses - SOLD
Battery Tray - SOLD
Campus Rear Window Seals - SOLD
Window motor
Regulator
N/S inside window surround
http://i191.photobucket.com/albums/z...psedddc50d.jpg
Passenger seat frame plastic cover (often missing!) - SOLD
2 x Clocks top visors - ONE SOLD
Fuse box cover - SOLD
Boot wheel arch plastic trim (drivers side - one without the boot light) - SOLD
Speaker grills - sprayed black - SOLD
Rear Door Card Pockets & Ashtray
Gear Gaiter - Poor
Fuel Tank Cover (under back seats)
Rear Lap Belt - Silver (Needs a clean)
Dash windscreen vent grills
Ashtray metal cage
Sunvisors - 2 x mirrored passengers, 1 x drivers
Rear view mirror
Drivers interior door handle
Passenger and Drivers door handle trims
Passenger and Drivers storage trims (passengers is for a glovebox delete)
Campus grab handles
Campus gear knob
Rear seat belt buckles
Steering wheel boss
Steering wheel centre bung / badge
Rear wiper cover and screw (campus)
Mirror covers - 1 x with hole for adjuster (comes with holder behind), 2 x Blank for aftermarket or campus mirrors
N/S door latch and lock solenoid (overspray on latch)
http://i191.photobucket.com/albums/z...ps80ebc0a3.jpg
Clear side repeaters - SOLD
Campus Horn - SOLD
2 x choke cables - BOTH SOLD
Accelerator pedal cable - small
Campus front bumper blocks
Drivers GTT under light trim and bolt
3 x Oil breather pots
2 x Swirl pots and brackets
Carb top
N/S GTT wing mirror good condition - unpainted
Rear engine mount bracket and bolts
2 x dizzy caps and leads with king leads
Distributor - Volvo?, with cap and leads
http://i191.photobucket.com/albums/z...psc88f65c9.jpg
OE UNCUT netted Boost hose, great for original look - SOLD
OE airbox suspension turret bracket - SOLD
Front grooved discs (ALMOST NEW no lip, just surface rust from being off the car)
Rear wiper motor
3 x downpipes
2 x inlet manifolds - one with brackets etc
Brake fluid bracket and reservoir with strap
Scuttle panel OE jack bracket
Spare wheel bracket
Starting motor
Flywheel cover - Needs a wipe down
Rear Washer Jet
Heater matrix hose surround plate and rubber
4 x Fog light surrounds (one with overspray)
Bumper mount
Turbo elbow
Anti-perc solenoid
Steering column with ignition and key
Actuator
Pair Front GTT calipers and carriers with bolts and brake hoses
1 x GTT Rear caliper and carrier and pads
http://i191.photobucket.com/albums/z...ps432fa8ba.jpg
SFS small boost hose - SOLD
Venom Motorsport radiator long hose - PROV SOLD
Samco radiator small hose - PROV SOLD
Samco couple of random small hoses (look like breather / water ones etc) - PROV SOLD
Samco boost hoses - pair - SOLD
Samco single small boost hose
Vac hose and off cuts etc
A Pillar universal carbon effect gauge holder and TIM Boost gauge (was in my GTT)
http://i191.photobucket.com/albums/z...ps538d5a83.jpg
Kenwood 6 CD Changer and lead
http://i191.photobucket.com/albums/z...ps83c467d2.jpg
