As some of you may or may not know, I am the person who has actually bought the legendary clio maxi turbo. Between Neil and myself we come to an agreement on the price of the car and then the chase was on to collect it which nearly didn`t happen due to problem with the car we was going to use to collect the car and blowing the engine the night before collection but luckily a kind person off RTOC come to the rescue with his recovery truck.
My main aim is to use the engine block itself but sell many of the parts off due to wanting more power and to also put it into the new naples that I bought to keep it look o.e on the outside for the sleeper look and then sell the maxi as a standard 1.8 16v lump with some extras but so as many as its had which will be removed from the naples which is a 70k engine :)
the naples after driving her back
http://i32.photobucket.com/albums/d1...10507-1435.jpg
the naples and also my other turbo which is my astra coupe bertone (which is for sale!0
http://i32.photobucket.com/albums/d1...10507-1905.jpg
The new parts which I will be going for will include (at present, it could all change!):
38mm turbosmart wastegate
t3/t4 garrett rollerbearing turbo with 50 comp wheel and .63 rear housing
custom made manifold for external wastegate
3" custome made downpipe
3" custom made exhaust
siemens deka 570cc injectors (which may be upped)
adaptronic ecu with custom made loom
the spec list of the car when I bought it before stripping!
Engine
F7P 1.8 Litre 16-Valve
De-stressed and chemically cleaned to remove carbon and then acid dipped to remove scaly corrosion deposits from water ways.
Re-bored with main caps fitted to suit piston size.
Minimal surface reface for blueprinting
All Headbolt and Main bolt threads are re-cut and cleaned
Engine block is painted externally with a blue paint to enhance appearance.
Turbo oil drain fitting
Wossener 8.0:1 82.7mm Forged Pistons
Reworked And Balanced Crank
Brand New Megane Oil Pump
Baffled Sump
Modified Main Bearings
Arrow Steel Rods And ARP Bolts
Uprated Main Bolts
Wire Ringed Block
Standard Payne Head Gasket
APD Big Valve Head With Megane Inlets
Piper High Lift Short Duration Turbo Cams
Catcam Adjustable Pulleys
Standard Head Bolts
Green High Flow 803 Injectors
Adjustable Fuel Pressure Regulator @ 3.5 bar
Garrett GT28RS Dual Roller Bearing Turbo
Uprated 15psi Actuator
Braided Oil Feed Line
Pace Chargecooler System
Mocal 13 row Oil Cooler With Thermostatic Take Off Plate
Forge Atmospheric Dump Valve
Boost gauge
Low Temp Thermostat
Low Temp Fan Switch
Samco Cooling Hoses
Uprated Radiator
Braided Fuel Lines
Uprated Evo Fuel Pump
Fastchips 250bhp @ 15psi chip with 9.5k limiter
Pipercross Induction Kit (located in scuttle)
Heat Wrapped BBPT High Nickle Manifold
BBPT Stainless Downpipe
Stainless-steel Adjustable Decat
Stainless-steel Mongoose Full System
All New Engine Mounts
R19 4th Engine Mount
Carbon Fibre Engine Covers
Chrome Plated Rocker Cover
Chrome Plated Inlet Manifold
Chrome Plated Fuel Rail
Chrome Plated Cam Belt Cover
Carbon Fibre Heatshields
Transmission
JC5 Williams New Gearbox
Gripper L.S.D
Shot Peened And Polished Gearsets
Rebuilt By Bernie At C.P.S With Lots Of Internal Mods
B+M Quickshift Lever
Helix paddle clutch
Uprated Sprung Cover
Uprated Release Bearing
Brand New Drive shafts
Brakes
Hi-Spec 4-pot Alloy Front Calipers
325mm Grooved Vented Discs With Alloy Bells
EBC Greenstuff Pads (awaiting a change)
Braided Brake Hoses Front And Rear
All New Copper/nickel Brake Lines
Brand New Standard Rear Brakes
Suspension
Leda Adjustable Coilovers
Standard Wishbone Bushes
Powerflex ARB bushes
Carbon Front Strut Brace
30mm Eibach Spacers
Wheels & Tyres
Azev A,s 8.5 x 18 Wheels
Eibach 30mm (per side) Pro Spacers
225/35/18 Goodyear Eagle F1
Body
Full Maxi Bodykit(new shell awiating soon)
Carisma Renault 5 Rear Spoiler Cut and Lengthened 150mm
Modified Sills
Removed Rear Wiper
Removed Boot Lock
Removed Door Locks
Audi Door Handles
Removed And Smoothed Roof Rails
Removed And Smoothed Side Mouldings
Fitted Peugoet 306 Lights
Full respray in Triumph Roulette Green
Debadged Bonnet
Debadged and Smoothed Tailgate
Bonnet Modified For 306 Lights(carbon bonnet waiting to go on)
Removed Side-repeaters
Tinted Window Kit
Fixed Rear Windows
Phase Two Rear Lights
Alloy Maxi Style Fuel Filter
Spare Wheel Removed
Custom Dtm Mirrors
Single Wiper Conversion
Interior
Momo Steering Wheel
Rear Stripped(awaiting my Genesis and Focal install not yet fitted)
Cobra Evo Bucket Seat On Custom Made Subframes
Luke 4 Point Harness
Custom Built Roll Cage
Battery Box In Passenger Rear Foot well
I actually purchased the clio on 1st May 2011, and it took me in total a 13 hour round trip to collect the thing!
The car on the recovery truck:
http://i32.photobucket.com/albums/d1...10501-1729.jpg
The car in its state the morning after once I woke up:
http://i32.photobucket.com/albums/d1...10507-1458.jpg
http://i32.photobucket.com/albums/d1...10502-1514.jpg
http://i32.photobucket.com/albums/d1...10502-1537.jpg
http://i32.photobucket.com/albums/d1...10507-1625.jpg
http://i32.photobucket.com/albums/d1...10507-1626.jpg
Due to wanting more power the following parts were sold or are still for sale:
pace charge cooler (will be in the way of my turbo and external wastegate set up)
http://i32.photobucket.com/albums/d1...ale/cooler.jpg
http://i32.photobucket.com/albums/d1...le/cooler1.jpg
forge dump valve (never liked the noise myself):
http://i32.photobucket.com/albums/d1...10522-2003.jpg
carbon covers (going standard painted):
http://i32.photobucket.com/albums/d1...10520-1740.jpg
bucket subframes (williams interior ready to put back in):
http://i32.photobucket.com/albums/d1...10522-1950.jpg
manifold, downpipe and de-cat (going external wastegate and bigger downpipe and exhaust)
http://i32.photobucket.com/albums/d1...10514-1422.jpg
chipped high boost ecu (going standalone adaptronic ecu)
http://i32.photobucket.com/albums/d1...10508-1632.jpg
scuttle induction (will clash with the new turbo and external wastegate set up)
http://i32.photobucket.com/albums/d1...10519-2013.jpg
bucket seats (putting a standard williams interior back in with the rear seats)
http://i32.photobucket.com/albums/d1...3048393561.jpg
garrett gt28rs turbo (to small for what I want as going t3/t4 turbo!)
http://i32.photobucket.com/albums/d1...10509-2130.jpg
