Will a T28 off a fiat 20v coupe fit these volvo b18ft engine? Seen one on ebay into buying it if it goes cheap.
I have a t28 of a pulsar gtir .86 rear. Works really well on the b18ft full boost by 4k all the way to the red.
Needs a rebuild as I think it was letting oil through iirc.
Was going to get one with same rear .86 off ebay apparently only used for a day. He wanted £100. Was put off as it was a bare turbo. No actuator or oil fittings etc and it was a Chinese copy.
Mine is bare. I do have an actuator somewhere but no bracket. It is genuine garrett tho but does need a rebuild.
Just pulled it out, it has side play but it has no oil in the bearings so that's to be expected and no in and out play. Has a very small crack in the turbine housing from the wastegate usual place. It still has the gtir outlet adaptor aswell.
I have pix of it if you want?
sorry have to give it a miss need to do my rear beam again from somewhere first. thanks for the offer.:agree:
No wories
