Bosch 044
Hi all,
Quick one, looking at getting an updated fuel pump as it was recommended to get it changed when doing the conversion. I've seen a Bosch 044 going reasonably cheap. Does anyone have any expierence with these? They seem reasonably good
Cheers
Re: Bosch 044
You will just need adaptors for in and out so it fits your fuel lines, also it's rather large compared to the oe gtt it will fit but you can't use the oe gtt bracket, COuple of nice big cables tie's will do the trick though to secure:agree:
Re: Bosch 044
It works well and they are reliable too thats what most people run for bigger power. Glenn hi5 used 2 and i think scoff runs 2 also. I run just the one at the mo ;)
Re: Bosch 044
044 pumps are great though there are cheaper Bosch pumps out there with similar specs. Think one I'm using for a Mercedes and about half the price. Can't remember the number though but not difficult to find other pumps
Re: Bosch 044
Thanks all, I've found one at a reasonable price anyways. Can anyone remember off the top of their head the size of the fittings that I need? Also does it still fit next to the standard fuel filter
Re: Bosch 044
I think i removed the original filter and pump and fitted a new bracket to hold the pump in the same place if you can wait till sunday i can get a picture ;)
Re: Bosch 044
Yeah that'd be awesome thanks JP
Re: Bosch 044
JP did you manage to grab a photo mate? Just trying to work out how Everyone has mounted them and what they've done with the fuel filters
Thanks pal
Re: Bosch 044
i have an 044 used a longer bolt to the bracket to hold the pump on.
Re: Bosch 044
Bugger i ment to check if you wanted a pic and forgot lol will get one in the morning ;)
Re: Bosch 044
No danger matey Tatey :)
Thanks very much
Re: Bosch 044
I'm wondering if a group buy on 044 pumps would be of interest?:D
Re: Bosch 044
If there are some guys genuinely interest I can try and get one on the cards
Re: Bosch 044
Search on eBay,
Normally find them a lot cheaper than can purchase anywhere, as normally companies getting rid of old stock.
http://www.ebay.co.uk/itm/Bosch-0580...item1c3df3a6b6
The company I work for cant even get them in at that price.
Re: Bosch 044
Sorry for the poor picture but here you are ;)
http://i1307.photobucket.com/albums/...pshfp55dsu.jpg
Even used the original wiring to make it easier :)
Re: Bosch 044
That's awesome thanks man.
Where abouts have you located your fuel filter?
Re: Bosch 044
He he i have 2 if you look really closely you will see both in shot ;)
One before the pump one after. You can see the one after easier its the black alloy bit after the pump ;) they are only small but both use a brass cone shape guass which you can clean or replace. I take them out every year and drain the tank down and wash filters out :)
Re: Bosch 044
God they're s****y :) were they expensive? Do you know the union size to go the standard fuel hosing
Re: Bosch 044
Ha that makes it look like I said sh1tty. It was sw.a.nky I promise
Re: Bosch 044
I liked them as they were compact and i found them on ebay through torques uk good company for quick delivery and good quality too
http://m.ebay.co.uk/itm/160638355244
And they now do one directly onto the pump ;)
http://m.ebay.co.uk/itm/170939750894
Re: Bosch 044
Also not got a clue on the union size as i replaced all pipes :/
Re: Bosch 044
Beauty I'll get me one of those. Thanks mate
Re: Bosch 044
Not bad price those mini filters, might invest! :cool:
