R5 gtt & campus used spares. Can bring to scoffs rr day
Campus mechanical window winders pair £25
Doors: pair grey £30, pair silver £20, passenger red £10
Tailgate grey £15
Headlamps £5 each
Rear lamps £5 each
Anti roll bar £5
Rear beam £5
Seat belts £5 per pc
Glass £5 per pc
Petrol cap and key £10
Upper lamp trims £5 pair
Tail gate struts £5 pair
Gear selector rod not bent £10
Gtt filler neck £5
Gtt petrol tank inc sender doesn't leak £40
Oil cooler lines £5
Brake servo £10
Starter motor £10
Steering column £10 ph 1&2
Like new top strut mount bearings £5 each
Screen wash res £3
Front brake callipers £5 each
Rear brake callipers £10 each
Wiper stalks £5
Indicator stalks £5
Steering colum cowling £5
Fuse box cover £5
Red dot 6 slot front brake discs new boxed surface rust £50
Campus 1.4l engine £60
Gtt cylinder head inc water pump £50
Front subframe £5
Rear view mirror £5
Handbrake £5
Ph1 header tank reservoir £10
Clear indicators 3 pairs £5 per pair
Front wiper motor and mech
Front bumper block £5 per pair
Sunroof Britax £5
Ignition barrel and key £5
Pair of lowering springs £5
Alternator £5
Roof lining £5
Dip dim resistor £2
Front stub axle hub £5 each
Inlet manifold £5
2 1/4" down pipe Nickle pated £30
Rad fan and motor £5
Ashtray £5
Heater dials £5
Heater fan £5
Rocker covers with brackets removed £10
Scorpion full ss exhaust system 2 1/4" with 3.5" tail pipe £20
Payments can be made via pay pal gift email address is peter5gtt@hotmail.com
Or bacs transfer. ( I'm not going to screw anyone over with the PayPal gift I've been a member too long for that.
I'm working full time so please allow 5 working days for me to box up and post out.
*Please pm me your mobile number so I can send you a pic of the part.*
For exact description of condition plz contact via pm or text.
Cash on collection or can post at buyers cost
You can also contact me direct via Text MSG on 07706310067
Re: Renault 5 campus & gtt spare parts clear out
Are silver doors torx fit ment and for a gt turbo? If so very interested in them
Pete@Backyard Racing
Camber corrector bolts £15
Would you do them for that price inc' P&P? If so, I'll take 'em please.
Ill take ignition key and barel plus heater fan (if not badly worn on shaft) if you could do £15 posted
Rear brake calipers please But could you check they are free moving and the bleed nipple turns freely.
Also after rear beam, strut bearings, steering wheel and boss (if gt?).
Obviously will pick up and cash on collection :)
Pms sent to everyone.
Can anyone who's interested in a part plz pm me with the part your interested in and your mobile number so I can send u a pic of the part thanks :)
Front steel strut brace £5
Performance cam unknown profile came out of a good car to suit t25 £30
How much would these be including postage please pete?
Thanks
Ross
Was thinking of getting a phase1 header tank but need inlet hose attached to fit to waterpump from firewall bay.
How much would you consider with postage please?
£5 should cover postage. I don't have any hoses for it tho.
Open to offers. Can bring to scoffs rr day.
Heater fan and metal ring?
£5 heater fan and metal retaining clip
pm'd mate would like front bumper blocks :-) how much posted? defo have them tho
