What plugs would you guys recommend for a high boost C1J?
I'm planning on running a T28 up to a max of 25psi. The engine has low comp pistons and an uprated cam.
At the moment however, the engine is a freshly built unit and will be run in at standard boost pressure on a stock T2, so I don't want to fit any that'll cause issues in its current running in stage.
Thanks
Ross
