Clutch - What is the best one... (from old site)
<table width="100%" border="0" cellpadding="0" cellspacing="0"><tbody><tr valign="top"><td>Clutch
contributed by Ian Simpson
Three main choices from GSF:
R71500, specify Renault OE one.
R18914A - Sachs Clutch - Volvo 440 - has a softer pedal than the Valeo one below, however, does not have such a high clamping pressure and may result in clutch slip with high torque engines.
R18914 - Valeo Clutch - Volvo 480 - stiffer, heavier pedal, higher pressure clamping plate, IMHO the better of the two if you have close to 200bhp and 200+ ft lbs. Make sure it's the Valeo make and nothing else by specifying "green box Valeo one" as GSF use the same part numbers on different parts and sometimes insist they don't have a Valeo. None of the others, eg the Sachs, LUK, will take anywhere near the abuse of the Valeo which will take 200hp no problem.
So that's the Valeo Volvo 480 Turbo 200mm 3 piece kit in a green box. Valeo part no. 801015. GSF part no. R18914 CLUTCH KIT-UPRATED R5 NEW SHAPE TURBO-HEAVY DUTY £72.60 + VAT.
This is also popularly used as a cover plate for a Cerametalic paddle clutch, eg, the AP Racing CP4814-25, retail price £138.79 inc. AP won't supply direct so you have to go through an authorised dealer. Try http://www.techcraft.co.uk/. You just throw away the centre plate from the Valeo kit and use this instead. Also a Helix centre plate is sometimes used.
Part No.s correct at 5th January 2006.
Price of Valeo 801015 correct at 30th March 2009.
Addendum
GSF have recently changed all part numbers for all clutches... now they are known by their LUK, Sachs or Valeo number with an 'R-' in front of it. Eg, R-801015.
Per Sparkie; if the gsf parts person has any sense at all they will easily be able to press the 'A' for alternative button on his screen and it will bring up the correct part number. assuming they have typed in R18914 ....
Per BrettM; if anyone has trouble with GSF again call Jason at the Ipswich branch, he has the account with two big tuners so knows the part numbers off his head! I've had trouble with the Thurrock branch and would rather wait a day for Jas to ship it!!!
As of 30th June 2006
Ian S RTOC Profile https://www.rtoc.org/boards/images/bu...iend-small.gif </td> <td width="15"> </td> <td width="200"> https://www.rtoc.org/articles/i/autof...14_150x140.jpg
</td></tr></tbody></table>
