Re: Minor Occasional Misfire
check the tdc wire that it hasnt melted etc... and that the sensor its self is ok
TDC Sensor is in good nick and appears to be doing the job. I check the spark plugs next as I remember Brigsy saying new plugs cleared up a misfire that he had on his Extra Van?
NGK or Champion plugs of the correct variety are not sold in Oz, so i'll have to go with the eBay UK option or similar?
Also did the Ian S addendum mod and made no difference.
check/replace the engine block earth lead.
Check the lead from the flywheel sensor where it goes through the bulkhead, it can
wear and short out.
fit a new relay on the overboost circuit.
Russell, the addendum mod replaces the over boost circuit.
My AEI is the engine side of the bulkhead (phase 1.5?) so doesn't pass through a bulkhead.
I'll check out the engine earth strap and maybe chuck on an extra one for good measure.
also check the dizzy and ht leads
If shes rich on cruise chances are the plugs may be fouled up, whip them out and see:)
