rogerreno
I see your 21 is the best colour they came in!!! Have you still got it?? I've still got mine (BOB) and he's running a healthy 260bhp and 248lbft torque.
I've done a lot of work to the head and manifolds, opening the ports up quite a bit as this is the most restrictive part of the engine (as its basically a std 2.0L N/A head with different valve guides)
If your running any kind of cam i'd give it a bit more boost..no point fitting one if your not gonna give it anything else..I've got a mild cam in mine, also a bigger turbo, injectors and adjustable fuel pressure reg with more fuel pressure.
I usually run around 18psi on the road and in overboost mode will run 22psi.
It is there...you just gotta find it!!
Cheers,
Roj
