throttle bodie injector possitions?
I am in the process of installing a set of hayabusa throttle bodies to my f7r powered 5 but am having a bit of a :scratch:!
does anyone know if it is okay to keep the injectors in the head as oe or should they go in the actual throttle bodies themselves?
thanks peeps!
Re: throttle bodie injector possitions?
you want the fuel to be as atomised as possible, as in a fine a spray
I've seen a twin injector setup on a throttle bodied F7R before, they had a set of standard injectors in the head for all the low down fueling but after a certain amount of throttle they switch off and a second set mounted pointing down the throttle bodies cut in
If the throttle bodies have the injectors in them already I would prob fit them there, could make some plugs for the head and plug the original injector holes up
1 Attachment(s)
Can't use 'standard size' injectors in the busa bodies, you have to use pico injectors to go in them.
Btcc cars had 8 injector setups, only really worked well if they were directed into the trumpets.
Matt@CodeRedMotorsports
F1 cars work in a similar way with top feed injectors
