http://i50.photobucket.com/albums/f3...psd0c2866d.jpg
http://i50.photobucket.com/albums/f3...ps4f22d7da.jpg
block with crank (not pictured yet),
exhaust manifold, downpipe, elbow,
alternator, clutch and cover, paddle clutch (1pair of pads removed to replace, needed),
2x rocker cover,
chain cover, sprockets,
2x fuel regs,
2x oil breather,
sump breather pipe,
new dizzy,
2x knock sensors, 1x lead to aei,
oil sandwich plate,
new headgasket,
king lead,
2x chopped tdc sensor/lead,
2x degaussing pots,
header tank,
washer bottle and pump,
2x plastic carb tops,
ph2 aei bracket and casing,
2x ph1 aei
rad bkt,
3x indicator retaining springs,
choke cable and lever,
horn and compressor (not tested)
ph1 fuel pump,
2x short boost pipes, 1/2 main boost pipe,
oil breather hoses (mixed)
air box top,
anti perc valve,
dash top,
mirror triangles,
heater controls,
dash vents, ash tray, dash flap, 3 gauge pod,
campus gaiter surround
petrol flap and hinge,
boot release,
rear light bulb board,
digi clock,
drilled/grooved/vented discs
dotted/grooved and vented discs
set of ebc green stuff pads,
2x set of std pads,
pair hubs,
pair wishbones,
os drive shaft,
pair hubs and driveshfts (os shaft shortened for gripper diff)
pair ball joints
pair brake sliders
2 engine mount rubber, 1 metal, 1 rear gearbox mount,
various engine bay brackets,
small splashguards,
steering column upper,
broken grille off my old 5,
2 sets of bumper slats,
towbar and electrics,
http://i50.photobucket.com/albums/f3...ps460b2d83.jpg
silicone boost hoses with ali dv take off, half telephone hose
http://i50.photobucket.com/albums/f3...pscf318774.jpg
http://i50.photobucket.com/albums/f3...ps2d90cbc1.jpg
red tailgate no rust
http://i50.photobucket.com/albums/f3...psbdf2ad72.jpg
http://i50.photobucket.com/albums/f3...ps4c60d5c4.jpg
peugeot lucifer red tailgate, no rust
std bonnet same colour
open to offers on job lot to make space, may split if not gone soon, space required.
