Hi does anyone know what the recommended minimum thickness is for the front and rear discs on a mk1 V6 Clio?
Cheers Ashy.
Cheers Ashy.
thickness... i swear its 330 dia, but hold on ile look it up for ya on the thickness side
think this is the set size
Front are 330 by 30
Rear are 300 x 24
i remember seeing a tolerance of +/- 2mm but thats alot... why what you got going on ? hmmmmmmmmmm ashy tell! you replacing your brakes?
ive got an MOT due (well over due now) I got an advisory at the last one for the discs being grooved slightly. I thought I'd whip the discs off and skim them up at work to save buying new and just fit new pads. They look like theres still plenty of meat left on them but just wanted to check what the min thickness was.
Thanks for the PM mate :) where did you get your new set of discs and pads from and what did they cost you? (if you dont mind me asking) :coffee:
Front disks from Ktec and mintex pads front and rear, also braided lines with discount.... came out to 440 or 480 i think.
cheaper than renault thats for sure ;)
aye I think I might have to pop my cherry and spend some cash at K-tec :ashamed:...
They seem to be reasonable on price compared to Reno!
yeah and you dont need the bollox of pads if your only driving normaly on roads.
To be fair getting the brakes done is a good selling point, and as it is that your selling.. i would :) also wheels.
the thing that sold the vee except the grunt and noise was re furbed alloy wheels and the brakes in a box that went with it:)
Well ive found some useful info on Cliosport at last :agree:
https://www.rtoc.org/files/Technical%...rbo/Specs2.pdf
So on the vee i'm only allowed 1mm wear on each side :eek: feck, best buy some new ones then!
