What can cause one of my wheels to lean in at the top, the drivers looks perfectly stright,but passenger side looks to lean in? I thought this was not adjustable unless cam bolts are fitted which mine has not?
Jack up and check all bushs and bearings mate
Wheel spacers? Are both bottom arms in right? Mind you if its handleing ok is strut top ok
I had the same problem and it turn out I had bent the standard shock.
Mixed up the top mounts, or you've fitted 2 the same.
New/different wishbone fitted?
i've had a bent shock too.... and a bent hub!
easy way to check it put your hand behind the tyre and see if the shock ->tyre gap is the same both sides. if not, then one of the two items is bent. if it is the same then suspect bent subframe, wrong length wishbone, wrong topmounts etc etc
Cheers lads I will intestate tomorrow night,and see what's up
