is anyone using the standard gtt rad? how have uou plumbed up the bottom rad hose? I bought some superflex hose hoping it would curl round but it is as fcuk!!:mad: just wondering how evreyone else has done it for a few ideas.;)
You need a metre of 32 mm flexible rubber water hose and need to take it under the oil filter, then loop it over onto the gtt rad outlet, think you cut it down to around 70cm
thats what i thought of and have the hose but just getting it there without it hitting the fan is a prob. well im going to stop being a pussy and make it fit:smashpc::laugh: cheers matey;)
im using a slimline fan, so that helps me a bit :cooter:
I'm using a samco original bottom hose cut down a bit.
But my rad is as far to pasanger headlight as possible. Or shal I day was
all sorted now. I had all ready moved the rad over only about an inch tho as the intercooler pipes need to come back through there. used the 32mm superflex pipe wrapped it round the filter. Not looking foward to changing the filter after flushing the engine:rolleyes::laugh:
hows your car looking dave what have you decided to do?
