Re: what injectors & turbo
0280150431 is 346 cc -->saab reds
0280155759 is 315 cc --> volvo 850 T5 (i have these for sale :) )
I had saab reds but they overfueled off boost so using t5 orange ones now seem a lot better.
I'm gonna use the big mod computer. this moddification can cope up to 480cc :)
there only +_ 10 made with this mod.
we will see what it brings
but 315cc should be fine to get 200 WHP
How did you come about gettimg one of them then matey?
SCHWARTZ
found it on the internet :) www.marktplaats.nl
Wouldnt go for either of those turbos as im told the bearings break up. Stick with a genuine garrett turbo off a 200sx t28 with the .64 rear off the later models. The water pipes and oil return off the volvo t2 bolt up also.;)
SCHWARTZ
Or you could just have new genunie Garrett bearings fitted to it ;)
Markey Mark (BD)
what sort of money would that cost to do any idea?
Shakes
I had Adam L do mine while ago, can't remember cost to be honest.
He did comment that it was one of the best balanced turbos he'd done, should work well enough but i've only got it for while, sure i'll change it for something else in future
just a quick one, are these the right orange t5 injectors mentioned http://cgi.ebay.co.uk/BOSCH-30LB-30-...item43925ff2f4
i know it says ford but just typed the injector number in, think its somthim to look at changing aswell
dont look anything like them matey, they look like the standard ones but are orange instead of brown
these injectors are to small ( 41 mm ) ev1 type
we need 65 mm
