Re: My Flaps not working...
I would pretty much say that they do feck up over time.. Best way to test is in some hot water or air and monitor what the temp of the supply air is until it opens..
Yes I would imagine they do just the car feels pretty good so cant imagine its bypassing the intercooler completely but the flap was deffo shut after a 12 mile blast just curious as if it makes the car feel even more lively if I took all the gubbins out thanks for the reply Dave..
I can't see it making a massive difference unless its not working properly.. Get a cheap 2nd hand one, flow that and try :)
I seem to remember that you could take out the thermostat part in the intercoolers and replace it with a bolt of the same thread and as you screwed it in at a point the flap opened up :/ it would there for open it fully and hold it there :) been a long time since I looked at a std cooler but that rings a bell :)
Thanks for the info on that guys I`ll buy an old cooler and have a fiddle about will be worth a go thanks again...:)
JP Racing
not the only one who remembers that one:cool:
deffo route to go if you want the full flow of the o.e cooler, dont pull it apart unless you really have to;)
if your taking it of the car , fill it with water and hang it up for a few hours and check for leaks also, o.e items where known for having issues:)
Cheers JP/Handy swapped the thermostat over with an M10x20mm bolt holds the flap open fine seems the easiest method.Never thought of filling with water and checking it will give that a go at weekend as its allready too late :( as opened up the cooler to have a poke around but after checking it over and going for a little blast car felt great no funny boost leaking noises and the gauge still reads the same in the car..thanks again for the info..
