lots of goodies from turbo clio - Brighton - priced
I am away from friday 17th to sat 25th so any posts or pms will not be answered. thanks
Pace charge cooler kit - £200 delivered
Bosch 802 injectors - £40
Garett T28 with adaptors, brand new water unions and oil feed and drain fittings (no actuator) - £210
K-Tec janspeed downpipe, only a month old - £250
Log manifold - £60
Fast chips low and high boost F7R chips with mid board - £210 for both delivered
turbo oil feed T piece (for F7 Engine) and feed line and fittings - £50
Turbo throttle body adaptor plate - £50
megane 225 rods - £50
1.6mm Athena racing head gasket( used but in good condition) reusable :) - £ 80
Arp 2000 m9 rod bolts - £60 delivered
baileys header tank with a new pressure cap - sold
FSE fuel pressure reg with gauge and braided hose - £60
AUTOGAUGE 52mm SILVER FACED TURBO BOOST GAUGE (psi) - £10
renault 21 turbo 2 bar map sensor - £30
Re: lots of goodies from turbo clio
why are you selling mate?
could you take measurements of the pistons? i'm pretty curious what they will do in a f7r!
cheers Arthur
Tutuur
cheers Arthur
What measurements do you want bud?
Does the battery box relocates to the boot?
Lol, al of them :D
First dibs on the clutch, is it Helix plate and cover? Just a valeo bearing?
200mm?
Cheers
groky
Hi yes it does, its a £60 box from deamon tweeks with 110amp cable and a 400amp circuit braker i had to source from the usa and also a junction box to connect under the bay. cost me a good £100 a month or so ago. cheers
Tutuur
Lol, al of them :D
200mm?
Cheers
hi yes its a helix plate and cover with a valeo bearing and yes 200mm.
its yours if you pay the postage lol.
and the pistons are 82.7mm megane 225 turbo pistons 8:5:1 comp ratio.
well i'll atleast take the clutch of you mate:)
u used the pistons in a willy engine right? do you know in what c/r that resulted?
I have not used them bud, was going to before decided to sell up. And where is it being posted to? Cheers
Mike cant believe all the work and effort and come to this i understand though matey, goodluck wih sale i can vouch how good all the parts are:agree:
have you got a BB Perf heatshield ? the one in carbon/kevlar ???
Ill take the battery box and its accessorys how much delivered?
i would say £60 delivered :)
romain-gtt
a what??? its a clio not a 5 bud :)
Mikeb185
Bbpt did a kevlar jobbie for the clio that goes against the bulkhead were the std heatshield would have been think coops has one on his
Agh I see... No I don't have 1 :)
Pistons, wheels and paddle clutch now sold :)
James heat shields are for wimps, let it burn:laugh:
Lol, you should put your hand on my bonnet after a spirited drive. Let's see if you hold on for more than 5 seconds :laugh:
Battery relocation - sold
Tutuur
Really:eek: I can put my face on my plenum after a blast. Where's your turbo mounted?:scratch:
Re: lots of goodies from turbo clio - Brighton - priced
Oil cooler setup - sold
Afr kit - sold
255 pump - sold
