*Help* Wideband wiring harness! Where have you put yours?????????
Hello peeps,
Just bought a wideband for the 5, looks fairly straight forward,
Just a bit worried how the wiring harness (and quite chunky connector block) goes through the bulk head into the dash, :scratch:
Do you have to drill a massive hole???:sad2:
How did you all manage yours and where in the bulk head did you put it???:confused:
Thanks
HULK
Re: *Help* Wideband wiring harness! Where have you put yours?????????
which wideband kit is it ?
HULK
NGK Powerdex afx
oh,not had that one so i cant help you.
I only want to know where i can feed the wires from the bosch sensor through the bulkhead into the cabin???
doesnt matter which one it is
HULK
well i fed mine through the little hole in the scuttle.
i've also fed wires through where the o.e boost gauge hosing goes.
it will fit through a hole near the battery,no need to drill the bulkhead,i think you will need to pull out a rubber grommet type thing though
