Knock sensor
Does anyone know if there is any knock sensors out there there compatible with the renix 209 that have longer cabling than the std GTT phase 2 item??............. Possibly another renault with C1J ?
Reason I ask is that I wish to hide the wiring and re-route it. Or would I be ok to chop it and extend it?
Re: Knock sensor
Not sure if the R11 had a longer fly lead with compatible plug. Worth checking. I imagine as long as the resistance in the cable is similar to that of the original, then jointing using correct methods should be okay.
