Bit of a long shot....but....does anyone have a JB3 and JC5 apart at the moment?
Need measurements of diff pin please.....diameter and length, basically seeing if the two diff units are interchangable/same. Ta Matt
they should be interchangable mate as I recall quaife listing the same diff for both the clio and the gtt.
page 4
http://www.quaife-differentials.com/...s-brochure.pdf
I'm ex-quaife.....Both JB3.....
Not that i've had my nose in a gearbox manual recently.... :D
prob already got this but http://www.scribd.com/doc/2490905/Renault-Gear-Boxes
It has the repair and rebuilding procedures for JB and JC input and output shafts and casings in individual sections, however, doesn't seperate the diff (other than the two bearing types) and all the part no. etc it lists are the same on both - page 66 onwards... so they would appear similar, not that helps much, would the renault parts system list parts for the diffs internals? as matching part no, might give you idea without one infront of you :crap:
I'll give Dialogys a bashing in the morning. Cheers Oli.
By the way mate, did a trial run on a Clio subframe..... Yours is going to be a beaut! ;)
